402-418ci trap speeds
Hi all. I was looking to compare trap speeds from 400ci setups. Specifically in the 402-418ci range.
I feel like my car doesn't dyno as well as some stroker setups but wanted to compare my mph to others.
2006 GTO
416ci
500whp
3600 raceweight
Best trap speed is 126
DA was +1500
Looking for car, weight, displacement, whp, and trap, DA. Thanks to all that contribute.
2006 GTO
416ci
500whp
3600 raceweight
DA was +1500
car is 3706 w/o me. im between 140-145.
t56 w 4.11 gear
28x10 et drag...works for the n2o but not so great for the motor. going to make some drag radial passes very soon
416ci 520-530whp depending on the weather
traps are 127-129 on motor, havent hit 130 on the slicks.
dont know the da...my best pass was in the middle of july in florida.
t56 w 4.11 gear
CARTEK Racing
Depending on the race weight and the motor you should be well above the 130 mark.
I traped 132 with a 346 and 3300lbs race weight...
A well build 402 should put down at least 50hp more than my 346, that should trap 136 or 137 given all other variables remain the same...
My race weight is 3500+
It's a GTO with a mild cam and auto car. I think 127 will be about my maximum.
Car is completely streetable. Driven to and from the track. Bone stock suspension. No trailer queen drag style tricks. Just a mild 416 setup in a GTO.
