Installed wolfe sway bar, need adjustment help.
Hey fellows,
I bought the wolfe sway bar used (never installed) and it did not come with adjustment instructions. Went to wolfe's website and got there installation instructions, but at the end they refer you to the "Provided in instructions which come with sway bar." lol.
Thanks,
Rick
Thanks,
Rick
the way we setup the sway bar on racecars is disconnect the bar end links then get the chassis fully loaded (ready to race even with driver) then adjust the end links where you can put the bolts in with no resistance (no preload). thats baseline then you can adjust preload from there. hope that helps
