Help me get a better 60 ft!
I cut a 1.858 60 ft on Koni/Strano Combo.
I have a 4000 stall and this is how i would run.
I burn out hold it in first gear at 6K and then roll out of the the box while burning out.
I stall it up to 1500 and then just roll the peddle down.
Can i just stab the throttle and these tires will hold? Will that yield a better 60 ft?
Does removing the front swaybar help with weight transfer?
Be prepared to tinker alot to get good times... fool with tire pressure carefully, launching techniques, etc. What kind of T/A do you have, what rear/gears, LCA's and location?
I do leave it in D, I just burn out through first.
Stock torque arm, 3.23s, 10 bolt, BMR LCAs rubber poly bushings, on the highest bolt on LCA brackets.
Are you saying my Koni Stanos suck for drag racing? Or the tire set up?
-00cls1camaross
at my buddies house
