mounting battery box by the books.....
To my understanding, the box has to be mounted to the frame rail, correct?
Is there any way to mount it to the rear floor/ttop well and pass tech? I thought I remember reading that you can run a plate under the box that attaches to the frame. Anyone know the specifics on that?
Thanks guys!
Thanks guys!
Mine is in the T-Top well- no issues with tech anywhere I've been as far as mounting & I agonized over this issue before installation after reading the rule book. It's bolted down with big fender washers. I have a Taylor vented box, got a comment from the tech guy at Capitol in Bowie, MD that it needed to have a "firewall" blocking it from the rest of the car but he let me run. Unless the rules have changed in 2009 I'm pretty sure he was wrong.
9-Second Club
Unless your battery has a vent tube (some race batteries do) that go outside the passenger compartment, he is correct. My batteries are mounted in the T-top well also, using large washers. No box, but a "firewall" that is a sheet of aluminium that covers the well. A winged Dzus fastener on each end. Has passed NHRA & IHRA Super Stock tech at divisional and national events all over the southwest. I have also seen firewalls like Wolf Race Craft sells passing tech also.
Race your car!
Vent the box,and you don't need a firewall.
I have a moroso box, that is mounted on 2 pieces of round bar that was welded to the front of the t top well, and the back of the trunk, probably 6 to 8 inches off the bottom of the t-top well, ran the vent tube right out the side of the box thru the bottom of the t top well, easily visable to a tech guy. They have looked it over at several tracks and noone has ever had anything bad to say about it.
No "firewall" or any of that, and it's fine.
Now if I put a fuel cell next to it, absolutely it will need a firewall/bulkhead. But... that's why the fuel cell goes in the engine bay No need for the bulkhead
fdfdfd
run a diesel. you'll be ok mixing the vapor w/ spark.
Race your car!
Aah. At least it's useful weight then.
Surprised it runs faster with the ALT hooked up then with 2 batt's.
Are you running 12 or 16 volt? If they're 12 volt I can understand, if they're 16 I'm a little surprised to hear that. Unless there's a rule stating that you can only run 12 volt, not sure what the rules you have to abide by are, I know there's alot of small things like that, all of which make it a good bit harder to go fast when they're all put together.
9-Second Club
It runs no faster with 16 volts. With 16 volt batterys and no alternator my data loggers shows the same voltage going down the track, but in later rounds we don't always have time to recharge the batteries. Guys have had problems with water pumps, cooling fans, fuel pumps, etc, running 16 volts with a 16 volt alternator, and I have not had one any long between charges than 12 volts. Fewer problems long term with 12 volts and an alternator. All it does faster with 16 volt batteries is run the power windows up and down and spin the starter faster.
