Drag Racing Tech
twistin problem
Old 01-13-2010, 10:18 PM
TravisMcGill2000's Avatar
Default twistin problem
My ta is twisting to the passenger side very bad at launch. The car actually sits about a inch lower on the pass. side. What kind i do to fix this. The car does not have sfc on yet. Ive already bought some umi sfc. Just havent had time to put them on yet. Ive got adj. phb, adj. rear shocks, and non adjustable lca's. I will try and post a picture of launch. thanks
Old 01-13-2010, 10:29 PM
Old 01-13-2010, 10:59 PM
5.3LJimmy's Avatar
Some lower control arm relocation brackets and a drag bag on the right rear for a street car. If it's mostly used for racing you may want to put a drag sway bar instead of the air bag. It would also do you some good to install the subframe connectors. What springs are on the car now? That thing is doing some serious squatting.
Old 01-13-2010, 11:11 PM
there stock springs. running cheapo stock replacement struts also. Its a 50/50 street car/ race car
Old 01-14-2010, 08:34 AM
tee-boy's Avatar
that looks bad. must be leaving on the spray.
I imagine the unibody is dimpled
Old 01-14-2010, 09:54 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
UMI rear drag bar for the win. Here is my old Formula twisting up back in 2000:
Old 01-14-2010, 10:44 AM
UMI Performance's Avatar
Like John mentioned a drag bar will cure that issue. Do you have a rear sway bar on it now?
Old 01-14-2010, 11:09 AM
AChotrod's Avatar
My UMI drag bar showed up yesterday!!!!! Very stout pc and looks killer! Cant wait to slap in on!
Old 01-14-2010, 11:21 AM
KCFormula's Avatar
You ain't got crap on Joe
Seriously though, 6pt and an anti-roll bar will fix it.
Old 01-14-2010, 12:56 PM
tee-boy's Avatar
squat anyone?
Old 01-14-2010, 01:05 PM
Race your car!
JL ws-6's Avatar
KC is that joe van o's car? Jesus what did he do try running it with no swaybar at all? That's the most twisted I've ever seen a 4th gen car leave.
Drag bar ftw. IMO, to get a car down the 1320 right, that is the first suspension mod I would do, even before anything else... after that start with the control arms, relocation brackets, tq arm, phb, shocks springs etc.
Old 01-14-2010, 03:03 PM
k thanks guys. yea i do have the stock 1 on
Old 01-14-2010, 05:47 PM
KCFormula's Avatar
Originally Posted by JL ws-6
KC is that joe van o's car? Jesus what did he do try running it with no swaybar at all? .
Yeah, I have no clue what he had on the car at the time.
Old 01-14-2010, 10:06 PM
BADHAWK51's Avatar
UMI drag bar for sure here is a before and after pic stock sway bar vs UMI drag bar.
Stock sway bar.
UMI drag/sway bar leaving perfectly straight.
Old 01-15-2010, 07:48 AM
mad_steve's Avatar
I can get you a Wolfe single anti-roll (rear sway bar). The Wolfe piece is a real nice product, since it all welds on. You'll never have to worry about it moving on the rear end, which i have seen recently on other rear sway bars. If you're interested, please call me at the shop. Our number is 225-673-3533
Here is a link to the Wolfe anti-roll in our online catalog:
http://www.madmanandcoracing.com/sho...spx?itemid=103
Old 01-15-2010, 07:50 AM
Old Geezer's Avatar
Talking My experience..
Installing connectors, etc, on a bent chassis = connectors installed incorrectly....
I'd suggest you have the chassis straightened on a frame machine, then install your parts.
Locking a twist in a chassis, then trying to tune it, is like a "monkey phuckin a football". Nothing good will come of it.
Furthermore, if you are making enuf power to twist it, it needs a 6 pt rollbar, at minimum. Frame connectors will help, as will an antiroll bar. The 6 pt will really tighten things up, and make the car much easier to drive/tune.
BTDT...The Buick in the sig had bags, stock rear sway, 6 pt. Still was a "handful" @140. I added the HR PARTS antiroll, ditched the bags, and the stock rear sway.. Whole new car!
But then, it is "only" a 6 banger...
Old 01-15-2010, 07:55 AM
Race your car!
JL ws-6's Avatar
OP: is the car actually twisting, or is it just rolling over? Old Geezer brings up a good point, you need to make sure the chassis is strait too, before welding anything in.
I'm hoping you have frame connectors and whatnot on the car already so that there's no issues there, and I'm hoping that there's already the needed safety stuff in the car, and that you problem is just suspension related.
Old 01-15-2010, 10:51 AM
KCFormula's Avatar
Sorry if this is off topic but what tire is on the back of your car?!?
Old 01-15-2010, 11:22 AM
Race your car!
JL ws-6's Avatar
Looks like a hoosier radial. Small one too by the 2nd picture...and it looks like it's on a 16 or 17 inch rim. Certainly not the same setup from the first picture, that looks like a 15 inch/28 inch slick combo.
Old 01-15-2010, 12:08 PM
Internet Mechanic
BlackScreaminMachine's Avatar
I have personally seen a car when put on jackstands, being it a level floor, actually teetering where we thought it was unsafe. We had to shim it before working on it.
Permanent Chassis Flex FTL!!
I put on SFC's (finally) and a UMI Drag Bar and the car responded very well. I hope to get a good picture of a hit off the line and see the diff!
