Drag Racing Tech
4.30 gearing
Old 02-15-2010, 11:13 PM
BOLO's Avatar
Default 4.30 gearing
I'm getting ready to buy a new rear end in the next few weeks and thinking of ordering it with 4.30's. Previous set up: 4L60E/4000 stall/4.10 gear on stock 10 bolt(took a **** last track outing) and 28" tires. Vid below in my sig--new best n/a--1.49 60ft. Do you think 4.30's would too much gearing? Trying to set the best combo. Any suggestions is greatly appreciated. Looking into an S60 or Moser 9".
Old 02-16-2010, 11:30 AM
kmracer's Avatar
whats your weight? trap rpm? shift rpm?
Old 02-16-2010, 08:52 PM
Scooter76's Avatar
I did a little math and with 28" tires and 4.30 gears you should be turning about 66-6700 at 122 mph ! If you lock up your converter the rpm's will be around 6300..... It looks like 4.30's will work . However , if you spray it you might run out of gear ! There is not much differance between 4.10's and 4.30's with a automatic !
Old 02-16-2010, 09:31 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
You don't spray the car anymore?
4.30's NA might be cool. My white Camaro was dual purpose so I ran a 4.10 gear NA but 4.30's would have worked better with my 28x10.5's...
Old 02-16-2010, 09:45 PM
studderin's Avatar
Im a m6 gone 128.5 on them, didnt kick the shiftlight at 6500ish. But the autp cars can be alot diffrent for your convertor. You almost have to tri it and find out if you wnat to get really close to ideal.
remebed too 28 etdrags grow to 29.0..... 29.5? maybe useing the gear/mph charts
Old 02-16-2010, 10:12 PM
Formula98ramair's Avatar
Just got a used s60 with 4.30s did have a 10 bolt 4.10s with 26in DRs 3500 stall have not had a time to take it out i dont think it well be that differnet ?
Old 02-17-2010, 12:50 AM
StreetSilverado's Avatar
Should be good on motor. I run a 4.33 in my 9" and I'm out of gear at 128mph with a 28" tire and converter locked in 3rd. No go if your going to spray though. I'm going back with a 4.11.
Old 02-17-2010, 01:10 AM
98_LS1's Avatar
how big of a stall are you running?
Old 02-17-2010, 01:42 AM
4000-4200 circle d 5c
Old 02-17-2010, 07:42 AM
BOLO's Avatar
If the difference is not much and can give me another 200 rpm, then it should work. And yes, I'm still spraying 150-175 shot or so. Trying to get the best from both n/a and spray. Thanks.
Old 02-17-2010, 07:34 PM
LS1Tech Co-Founder
What rpm do you shift on motor and on spray Butch?
Old 02-17-2010, 07:41 PM
BOLO's Avatar
Set @6800 on motor, 6500 on spray
