Launch Questions
Launch Questions
I think with this years motor changes I am making more power at the launch and overpowering / hitting the tires too hard. To get the car to work last year the Torque Arm is set in the top hole (all the way up) and the LCA's are set in the lowest hole (all the way down) on the rear end brackets. The front shocks have been set on 0/0, 1/1 and 2/2 while testing. Which on 0/0 should have the suspension set up to hit the tires as hard as it can.
I'm thinking that I need to adjust the IC to soften the hit since I think I'm overpowering the tires. I would do this by moving the LCA's up? The T/A down? Both? Or should I stiffen the front shocks up more?
Looking for any input or suggestions...
Car Info
3400 lbs Race weight (driver + fuel)
QA1 R's Single Adjustable Front, QA1 Single Adjustable Rears, Stock Springs
Stock K Member / Front End
Midwest 9" 4.56 Gear, T/A, LCA's, PHR
28x10.5x15 ET Drags w/Tubes - Tested at 10-12psi
T56 - 6 Speed
Launch RPM 6500 - 7000 (2-Step)
383 LS1 / Vic JR / Accufab TB
This was 7000RPM 1/1F 5/7R 10PSI
Video - 6800RPM 0/0 5/5 10psi
Video - 6800RPM 1/1 5/7 9.5psi
Video - 7000RPM 0/0 5/8 10psi
Video - 6500RPM 1/1 5/7 10psi
Video - 6800RPM 1/1 5/7 10psi (Hot lapped)
Car Info
T56 - 6 Speed
