Drag Racing Tech
need help with suspension
Old 09-19-2010, 05:35 PM
SS4Luck's Avatar
Default need help with suspension
Well my MWC parts should be here on monday, at least thats what fed ex says and i have no idea how to set up my coil overs. I got Strange DA's for all 4 corners with 300# front springs and idk what lb rears.
i know it should be tight rear loose front, but exactly what is a good starting point for bound/rebound on both.
also i plan on putting the tq arm in the seond hole from the top and the lca's in the second hole from the bottom. sound about right?
Car is a 2002 M6, a few hundred lbs of weight reduction. Cam only makes low 400wheel. Running a 28" radial on a 17" rim w/ 4.56 gear
also gotta figure out how to setup a arb
Old 09-20-2010, 06:18 AM
LS1Tech Sponsor
MADMAN's Avatar
LS1Tech 20 Year Member
The best thing to do is call the vendor you bought the shocks from and get a tune up.
__________________
www.madmanandcoracing.com
225-343-9029
