Drag Racing Tech
BMR trans crossmember, real crap piece
Old 04-09-2015, 08:39 PM
Taubr Unit's Avatar
Default BMR trans crossmember, real crap piece
Got a bmr crossmember for my '94 for a th400 and it couldn't fit any worse! First the bolt holes on the passenger side don't line up so when I milled out the slots to make them fit I had to cut the washers to clear the weld on the tube. Finally get it mounted on car and the passenger side is too high, almost like they cut the tune too short so the plate where the mount mounts too is on a big angle. So after shimming and grinding to make that work I see the trans mount slot is way off. Took back off and had to grind the slot further towards the trans to make it clear. THEN after all that crap, the mount is all together too low so I had to make a 1/2 spacer to make up the difference from crossmember to mount. All in all a real crap piece! And after a lot of research I see a lot of other people have the same issues. Iv emailed them and no email back. BMR, if your reading this I'm HIGHLY disappointed in this product.
Just a few pics...
Old 04-09-2015, 09:53 PM
ramairetransam's Avatar
your car was never in a wreck was it ? is it possible the piece is off just a little and bc of power your car has it has twisted it a little ?
Sorry for your luck man . i bet one of the bmr techs will get on here and chime in . Maybe they will send you another
Old 04-09-2015, 10:03 PM
Zmg00camaross's Avatar
Should have just traded the car for mine but that does suck. Should have hit up ole Eric at MWC.
Old 04-09-2015, 10:07 PM
Taubr Unit's Avatar
Car was never wrecked and my th350 crossmember fit perfectly and a wreck wouldn't change the bolt hole dimension. I did hit up Eric but after a few weeks of waiting I found this one for a deal And didnt want to wait longer.
Old 04-09-2015, 10:09 PM
I hear that. Let's see what BMR says.
Old 04-09-2015, 10:29 PM
25thhawk's Avatar
Haha, when I had a bad k-member everybody told me it was no big deal and just grind it a little and get it to fit. Its bullshit the amount we pay for parts that dont fit right. Really sux. On that note, my trans mount fits the car fine, waiting on the trans to see if it fits that. Not counting on it after some of the pics I have seen. Good luck with it.
Ryan
Old 04-10-2015, 08:46 AM
transampetews6's Avatar
My BMR 4l80e cross-member fit fine. Nice and sturdy. I got 2 from MWC and neither fit at all, light weight POS. I thought it might fall out. I shimmed it like 3/4 of an inch to make it work but the drive line was all wrong. I bought the BMR cross-member and it bolted right in. Total wasted my money with the MWC.
Old 04-10-2015, 10:31 AM
boss79z's Avatar
I also run the BMR TH400 crossmember and mine fit perfectly. Weird this one was so far off. I would contact BMR and see what they have to say.
Old 04-10-2015, 11:37 AM
Taubr Unit's Avatar
I called and left message and emailed, both with no responses.
Old 04-10-2015, 11:49 AM
StangEaterSS's Avatar
I run a UMI th400 cross member. fits great. I like them over BMR.
Old 04-10-2015, 12:11 PM
Boosted SS's Avatar
UMI- mine fit great when I had it on the car. Now I have Midwest chassis setup and it fits like a glove just like everything else from them.
Old 04-10-2015, 10:06 PM
Taubr Unit's Avatar
So after a few hours tonight I got it to work. Had to make a 1/4 spacer to lower the pass side to level out the mount plate. After doing that I had to made a 1/2" spacer to make up the lower distance now between the crossmember and trans mount. All this after I had to mill the slots longer and find longer bolts etc. Excellent!
Old 04-11-2015, 06:28 PM
25thhawk's Avatar
Are you sure the poly trans mount is right? That doesn't look anything like mine, and the part # doesn't seem familiar either.
Old 04-11-2015, 07:17 PM
Taubr Unit's Avatar
Yea it is, I have 2 different ones here that I tried and they all fit the same. Bolts to the trans and goes straight down to the mount, pretty straight forward piece. Either way that doesn't effect the way how the the crossmember didn't fit right ya know.
Old 04-13-2015, 12:09 PM
2001AntiVenom's Avatar
Lol I sent them a pm on 4/3/15 asking about a kmember and a arms and still haven't got a response. This isn't the first time either. On 4/6/15 at 6am I sent Umi the same message. Got a response before noon. So I bought all Umi through ws6store. Bmr needs to get their customer service under control.
Old 04-13-2015, 05:59 PM
insanez's Avatar
Good luck with BMR, I emailed them three times with an easy question ready to spend lots of money and never got a response. I already spent $1k at UMI and I still need a K member, it's between UMI and MWC.
Old 04-13-2015, 09:11 PM
high n dry's Avatar
UMI x mem here... fits great!
Old 04-14-2015, 09:10 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
MWC has four 4th gen cars here to fit our parts up to, and we are constantly checking parts to make sure all is well.
Keep in mind people these cars are not all exactly the same right out of the factory. The factory components usually have huge holes and fasteners with large washers to take up the gap. MWC components do not have large holes and sometime this can be an issue to where a hole may need massaged with a file.
MWC normally stocks both 93-97 and 98-02 conversion crossmembers for 'Glide, TH350, 4L60E, T56, TH400, and 4L80E trans combos. These are made with DOM seamless tubing and laser cut bracketry. If one desires a lighter weight version out of chromoly or aluminum we can do that but it is a build to order basis and can take some time to get through the shop.
Old 04-14-2015, 12:03 PM
BMR Sales2's Avatar
We apologize for taking so long to get back with everyone on their inquiries. We are busier than we have ever been and are short-handed here in the office so it is taking us longer than usual to get back to people. I will get with everybody here and make sure we get everybody squared away.
Thanks,
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 04-14-2015, 12:58 PM
Taubr Unit's Avatar
Sent you a pm back Kyle, thanks!
Quick Reply: BMR trans crossmember, real crap piece
