Finally in the 11's cam only.
Well got it in the 11's last weekend 11.94 to be exact with cam only and some new 4.10's in the stock 10 bolt. I was babying it out of the hole feathering the clutch around 4000rpm's and still managed a 1.73 60'. Cam is a TR230/224. DA was at 3000 feet at the time and was 84 degrees outside. I was using BFG drag radials.
Here's my run.
R/T .533
60' 1.738
330 4.985
1/8 7.677
MPH 92.15
1000 9.997
1/4 11.940
MPH 116.27
Hopefully on a cooler day it will run a little better and pick up a tenth or two.
Here's my run.
R/T .533
60' 1.738
330 4.985
1/8 7.677
MPH 92.15
1000 9.997
1/4 11.940
MPH 116.27
Here's my run.
R/T .533
60' 1.738
330 4.985
1/8 7.677
MPH 92.15
1000 9.997
1/4 11.940
MPH 116.27
Here's my run.
R/T .533
60' 1.738
330 4.985
1/8 7.677
MPH 92.15
1000 9.997
1/4 11.940
MPH 116.27
oh sure. You have any time slips to post???? Or did you just make those times up? Were you even at a real track, or did you just pretend? I'm calling until you post a time slip. Jackass. The next thing you'll be saying is you have a friend that went 12.60's in an.......AUTO! I think that you need to wake up man.
DA of 3000 feet...I don't think so...its funny when I figured the DA for that day it was about 1300. 84 degrees? Where were you, Florida?
Well anyway with all those mods you should be running 11.50s-11.60s. But hey, congrats dude.
Originally Posted by DEEZ98Z
Do you know this guy? If not your are a TRUE JACKASS!!! I went 11.9's in a cam only set up (which is nothing to brag about)... with what is in my sig So I am lying too huh... you need to wake up and realize that you are SLOW!!!
Restricted User
Tileman - When are you going back to the track? I'll tape you and 2002SilverWS6 going at it...
Originally Posted by 2001 Pewter WS6
Well considering the track is at an elevation of 1250' to start with...
Tape them! Will they ever get to see it???
