th400 users and speedo?
what do you guys do to make this work?
I have a 94 with a 6.0/th400 swap with ls1 pcm and ls1 front brakes if that matters.
I would like the stock speedo to work!
What needs to be done
Reluctor wheel and sensor out of a 90s truck u can peice together from gm dealer i dont have part numbers handy or these guys or tci can hook u up or use your front wheel speed sensor might just have to adjust your values in the tune for vss http://www.transmissioncenter.org/GM...eter_Gears.htm
I got the 90s truck setup but think the sensor maybe no good, so I've been looking into a GPS setup I've heard that you can wire it into the trans pigtail to work with the stock cluster.
