Drag Racing Tech
MSD 8733/brake pressure switch/abs
Old 08-25-2015, 02:00 PM
TXCatfish's Avatar
Default MSD 8733/brake pressure switch/abs
I'm trying to setup up msd 2 step using a brake pressure switch (60-120psi). When I apply a little pressure to the pedal the 2 step is activating, it should activate when I mash down on the brake (60-120psi).
Do I have a bad brake pressure switch or is it wired wrong. Also I still have abs so I don't know if that has anything to do with it.
Quick Reply: MSD 8733/brake pressure switch/abs
