MT ET Drag tire growth
8 Second Truck Club
I run tubes. I was totally against it at first because of the added complexity of mounting tires, extra weight, extra cost...etc.
Once I bit the bullet and decided to run tubes.......I will never go back to running without them. No leaks, not really any more difficult to mount the tires (use lots of baby powder) and seems to have stiffened the tires a little which helps with traction and high speed stability.
I don't run tubes. Low 1.30's with clutch dumps and now transbrake leaves. I used dawn dish soap on my tires before I mounted them. Mine hold air almost like a radial now. Only time I get sway is when I air them down below 15. But they seem to work best with 16.5 at the track and around 18 on the street.
Race your car!
I used to run the same 28x10.5s tire with 12.5 lbs all the time and never had any issues with sway.
People that have issues tend to start trying to drive the car when the back moves a bit and that's when it becomes a problem. Just let the rear walk a bit and keep the wheel steady and all will be well.
MTs are horrible for leaking, but as stated dish soap them and the problem should be gone! Hoosiers are pretty good for not leaking for whatever reason.
The swaying isn't really a big deal, let the car dance around, don't try and steer it or things can get hairy.
There is some goo you can get for tractor tires that acts like a lube when they pull the tire on and once the bead sets it sets up and basically glues the tire to the rim. Havent used it in a long time(years) but If I recall hot water broke it loose. We had to use it or when pulling a plow the rim would spin loose in the tire. We ran tubes full of liquid for traction probably not a good idea for drag racing.. LOL
