Worthless Mods = NEW BEST!
I decided to make a trip down to Sacramento and see if I could get some good DA's, new bests this time of year aren't easy. But, I normally run in 2000ft DA's. Although it wasn't the greatest weather in our low pressure front, I did see DA's in the 700-1500 range, with a DA of 969 at the time of my best. (71.6D 29.92Baro 22Dew) 8:00
I made 11 passes during the two days, but didn't mess with the tuning and my 28" Hoosier's weren't ready in time for this weekend. But I did get a chance to try out the modified airbox & ram air (the worthless mods). I'm REALLY happy with the consistency of the car, I didn't make ANY 11 sec passes. My best was as follows (ALL NEW BESTS):
60' 1.47
330' 4.40
1/8 6.88
MPH 99.13 WOW!
1/4 10.828
MPH 125.128 WOW!
The other passes were:
1.48 10.858 123.97
1.47 10.873 124.29
1.49 10.888 121.85 (MPH?)
1.50 10.895 123.95
1.49 10.899 123.68
1.50 10.909 124.06
1.52 10.910 123.50
1.54 10.920 124.19
1.51 10.935 123.59
1.51 10.944 123.59
That's 11 passes in a row faster than Terryble Terry! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> And not bad considering I race on a 10.90 Summit ET Dial. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I'm not complaining either with the positive 1000' DA's.
I'm just a bit concerned about a couple things I figured out after this weekend. My BEST passes the last 4 or 5 weeks have been on the FIRST pass. I think the trans is heating up and slipping. Even when the DA comes down some throughout the day/night, my MPH doesn't improve and the shifts seem to lag just a little. I may need a shift kit in the stock trans and I'll be looking for ways to get the temp down some more. I already have a decent sized trans cooler.
Engine temps are coming up to 200 now and I'm seeing knock retard. The car was missing slightly on the big end but I couldn't confirm from Autotap whether it was rich/lean. The numbers would jump around from run to run??? I would get KR with .940-.960 O2's. And a couple runs dropped down to .890-.910 with no improvement in ET/MPH without touching anything. And I thought I was going to be able to dial it in with the MAFT. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I guess I'll have to tune by track times and forget about ATAP.
I've also determined the 26" tires just aren't enough anymore. I can't stall up past 2400 without spinnning (1.52-1.54 passes). I think with the 28's, low-mid 1.4's consistently are in the bag. We'll see.
On a side note, the new Hawker Genesis (Dyna-batt replica) battery worked flawlessly all weekend. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
60' 1.47
330' 4.40
1/8 6.88
MPH 99.13 WOW!
1/4 10.828
MPH 125.128 WOW!
1.48 10.858 123.97
1.47 10.873 124.29
1.50 10.895 123.95
1.49 10.899 123.68
1.50 10.909 124.06
1.52 10.910 123.50
1.54 10.920 124.19
1.51 10.935 123.59
1.51 10.944 123.59
Re: Worthless Mods = NEW BEST!
Well I am thoroughly impressed with your new time of 10.8 something. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> You can put that worthless mod on my car anytime and fine tune it to boot. I know your counterpart on the other end of the West Coast must be crying now. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Keep the pressure on him and so we can get some new threads out of him. Jantzer that is quite a feat. I guess you are getting the attention of the "Pepper" down there in Texas <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> and he is most likely fine tunning his car with every trick in the book. Of course, the "Pepper" has to be recogized because of past records--deservingly so. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> Anyway I read your threads and try most of them I have to admit. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> In all honestly, did the air mod contribute to your new time in your opinion. I hope your transmission is OK and nothing is broken inside. The MPH was extremely fast and it appears that your ET can come down base on the high MPH if you can get that 60' down a little bit more. You are setting a high standard at this point in time and keep up the good work. Don't stop now, find a few more tenths and get the record. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Again, that was clever move on the air mod. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> Best wishes and good luck for the record.
Terry!!!!!!!!!!!!!!!!! Whats going on>>>>>>>>>
Scott knows the mods were worthless, his ET improvement was from better DA and a bit more weight reduction. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Congrads on the new best though! I was working on my car today too. I'm still waiting for my hood/brakes to come in so I can take a few more passes on this setup, and I have the LS6 heads/new cam on the way too. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I moved up a spot to #2 NA Stock Shortblock. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I'm WAY passed my goals for this heads/cam setup.
I'm seriously starting to wonder what this car is capable of with the upcoming 200lbs weight reduction, some LS6 heads that flow more than my little Stage I 275cfm, a REAL cam, 28" slicks, & -DA weather. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Holy $hit this coming year will be amazing. And then the T-brake!
Terry & I just had a steeper learning curve. Now look out!
I dropped 12 lbs, still ran MR. Spiderman antenna mod, and ran without my epoxied TB (pulled it out to powdercoat). I think the MODS are working. 99/125MPH at 1000ft. DA. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The thing that is amazing to me is the mph this car is running with the home ported heads <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Think about it, Scott you must have hit it right on with your port work. Your car is running more mph than these other cars with stage 2 heads, and more cam than you, and I'm talking about $2000+ heads that have major flow bench time and big valves and all.
Anyway, congrats and I want your help when I port my heads.
Albert
Albert
Scott's little heads are ported a lot more than he likes to let on, but you can't beat 125mph for a simple reliable combo. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
So Scott 6.88 is my new 1/8th mile goal? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Nice meeting you and your father Scott. It was also nice seeing that 10.87 pass. I got a lot more busy with my car on saturday than I had planned and didnt make it down on saturday, but I just wanted to say nice times. Look forward to watchin ya run that thing again and maybe next time I see ya Ill have my car running, not that ill be any competition lol..trying to get my stock longblock into the 11s...see ya around
Dave
Dave
Albert:
Thanks for the kind remarks. Being young, dumb, and numb to the fact that you can really mess up your heads, I went for it anyway. I like to challenge myself, luckily this is one instance the hard work is paying off. I spent over a year researching heads & porting techniques and talked to some old timers. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Terry:
To refresh your memory, the intake ports are only 212cc (smaller than the LS6 in stock form) vs. your 223cc+. The guide boss was only slightly streamlined, the rocker boss has only been rounded, and as far as I know, the valve job was never blended into the seat. They're stock intake valves without a backcut or anything, and REV 1.57 exaust valves. I'm not kidding when I say they're conservative. I'm amazed myself they work as well as they do.
I don't see any reason a 346 can't see 130MPH NA & a 9 Sec pass with a transbrake. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I bet we'll be closing in on that mark next year. If not with a stock shortblock.
Needless to say, I think the smaller intake ports & valves may be the way to go on the stock bore. I'm making a pretty good argument for that.
Dave:
I'm sure I'll make another trip down there in the not so distant future. That wasn't my Dad by the way, just an older friend. You guys squeezed my arm a little, I'll have to sign up over on Norcal-ls1.net. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Next time I'll stay a little longer and hopefully make it to a get together.
Terry:
Dave:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So when is the new heads/cam going in?
Jantzer, congradulations again on your new record. I guess you are on cloud nine being the second fastest in the country next to the "Pepper". I hope you the very best and it seems all of that hard work is paying off for you. Your friend---Kent.
Thanks Campbell & Chris!
The heads will be a while. I'm getting ready to build a flow bench, in reality they're pretty simple. ETA probably 2 months on the heads.
I'll be swapping cams probably next month. I want to see some more results with the reverse splits first before I make my final decision. I'm leaning towards a 232/226 XE-R intake/XE high lift exaust 111 lobe sep. But I'm concerned with P/V clearance with .030 off the heads. Maybe if I run a small intake valve margin I can get away with it.
What were the specs on that 232MMS cam anyway?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">All you need is a shop vac and a vacuum gauge to make a flow bench. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
The 232 cam is like the 229 cam only bigger.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Terry Burger:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
The 232 cam is like the 229 cam only bigger.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not exactly. You need a couple shop vac's for the kind of air I'm going to flow <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> , have to be able to correct for air, have a head adapter, accurate valve opening tool, etc.
Terry, I don't work for Cartek. You don't have to be sarcastic about the cam specs. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> What lope sep did Mike use on the 232?
Congrats! Nice times!
Now borrow someones kit and spray it. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Trevor:
We'll find out in the next month or so. We all know it'll pick up. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Guido:
Keep it on the low-down buddy. I won't be able to hold off installing the TNT Wet kit for much longer. You can bet your sweet **** it'll happy this fall if not sooner. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Guido:
