Drag Racing Tech
air bag! yes or no?
Old 01-04-2003, 06:10 AM
9secpacecar's Avatar
Default air bag! yes or no?
i am putting in 12 bolt,control arms,trogue arm, hal's fronts and drag springs,rear comp eng. drag shocks,should i use air bag? and what is the part # for single one? and how much air.tia.
Old 01-04-2003, 11:27 AM
ROB'S SS's Avatar
Default Re: air bag! yes or no?
it would depend on how the car launches. most people would recommend it im sure, but if you dont NEED the airbag, but you would have to play around with it. same as the air pressure in it. trial and error. probably be between 15-20 psi
Old 01-09-2003, 06:05 PM
Skelton's Avatar
An air bag can still help unless you go with a rear sway bar like the wolfe.
Old 01-09-2003, 06:09 PM
WJ SOM SS's Avatar
A very in-expensive and quite rewarding mod, if you play around w/air pressure and get it right... it'll help you. WJ. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old 01-12-2003, 04:48 PM
kevinb's Avatar
Where can you get an airbag and how does it install? Can it help out a launch with a car with hypercoil springs in it?
