Drag Racing Tech
Line Lock help?
Old 02-02-2003, 05:33 PM
SLowETz's Avatar
Default Line Lock help?
Installed the Hurst unit, bled the system(5 times)until there was no evidence of air in the lines. Solenoid engages,(and does engage the brakes) but doesn't hold the car still during the burnout <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Keep bleeding off the lines....or is there something else I could look at? TIA!.......
Old 02-02-2003, 05:34 PM
LSX Mechanic
Damian's Avatar
Default Re: Line Lock help?
Mike, call me...
Old 02-02-2003, 07:24 PM
xaon's Avatar
pull up, come to a stop. pump the brakes a couple times then engage the line lock while holding down the brake.
If it still pushes the car when trying to do a burnout, check for leaks while someone pumps on the brakes. I ended up having a few leaks on mine (that I found at the track AFTER driving 120 or so miles to get to it <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> )
Old 02-02-2003, 10:34 PM
Classic's Avatar
xaon is right. Sometimes you have to engage the line-lock and then pump the brakes a few times to build up enough pressure.
Good luck.
Old 02-03-2003, 12:00 AM
ROB'S SS's Avatar
uh, are you trying this on the street or at the track? mine wont hold the car on the street(front tires keep pushing), but works like its supposed to at the track <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
