Light weight windshield?
I saw someone on here talking about Speed Glass from a place call Percy`s I think. I saw a picture of a red Camaro with a rear hatch window and it looked as good as real glass. I think they sell a thicker Speed Glass for the windshield that dosen`t require you to have supports on the windshield like a stock car. Just remember the DOT thing that was stated above. Not everybody follows the rules, right?
How did you bend them? Wold you reccomend the door windows for a daily driver? Also dose it look like real glass like they say it dose. Hows it holding up to scratching since youv`e been letting the windows up and down.
The side windows have a curve in them. All there glass still needs to be cut. When the side windows went in there was a gap at the top about 7 inches. The glass wont break. you can bend it in a break if you want. What I did was mark about 1 inch under where you cant see the glass when its installed. Then I took it and built a vice off a table. Then took a heat gun and heated the bottom up. And pulled on the glass at the same time. It took a few times to get it where we needed it. But you cant tell its not glass. And it rolls up and down fine. Where I heated the glass up it blistered. So make sure you heat it where you wont see it when its installed.
If you are interested I can PM you a price on the glass
7 Second Club
Location: Grove City Ohio/Port Washington L.I sometimes
Windshield and hatch are going in my racecar next week.I bought Percy speed glass.
Per Derty's recommendation I bought the 3/16 windshield so I don't have to use a brace.
Originally Posted by GueSS Who
Can someone give me the link to the glass.
7 Second Club
Originally Posted by Slow Z28
now can you "glue" it in like the factory windshield or does it have to be bolted in/screwed in?
LS1TECH Sponsor
Dave, will you take pictures of the finished process?
I don't want to screw mine in.. and also don't want to do it myself. I want to take it somewhere to have it "professionally" done as I don't trust my work on that type of job.
7 Second Club
I'm going to trace the perimeter of the factory glass onto the lightweight
stuff.
Going to use a bandsaw and plenty of patience to cut it out.I'll paint the inside perimeter of the glass about 1 inch deep with black paint to hide the sealant.
My bodyman/painter will be around to help,he say's it's no different than putting in factory glass after it's cut to fit.
Price varies on the thickness you want.I bought the 3/16 inch for the front so I don't have use a brace.Got the thinnest they had for the hatch.The thicker it is the more it cost's.I'd have to dig the receipt out but it was around $500 for both.
I'll put pics up next week when my formally sebring silver car is sporting it's new 03 Z06 Electron blue paint.
I traced the old glass also. It was still a little off. But not far. Had to do a little more trimming in the corners in the back. I glued it in. The back hatch is a PITA to cut out. The worst part is the percy glass doesnt have the black ring around the back. So you can see the glue. I was going to paint it. Instead I made a peice out of black vinyl looks good. I make vinyl decals. and if anyone doing this needs the vinyl to cover up the back to hide the glue let me know. Or you could paint it.
Originally Posted by DopeFedZ
Their site says about 60-65lbs if I remember correctly for a full kit.
If you do the pin on hatch itself you loose even more weight. LOL
You can get an F-body down to 2500lbs with a driver and the safety stuff pretty easily.
