Hoosier Slicks Tubes or no Tubes?
10 & 11 Second Club
Originally Posted by gator's 99TA
hmm weird. i never like tubes. just something that could pinch and give me a flat. slicks tend to loose air in them faster but oh well. one should be checking the pressure often.
Originally Posted by 01-Z
I run tubes.29x10 Hoosier Drags
Seems like guys are split on the decision to run tubes or not. That makes sense, because Hoosier themselves say it's up to personal preference.
(FAQ link)
https://www.hoosiertire.com/Drtire.htm
Quote from Hoosier FAQ:
6. Should I use "tubes" in slicks and DOT drag tires?
ANSWER: The decision to run tubes is ultimately up to the racer. Hoosier drag tires are capable of safely running without tubes. The Quick Time DOT tires should be run with a tube when the tire is run on the street, but they can be run without tubes at the track. Race tires are inherently susceptible to air leakage due to being built of very light gauge material needed to perform in various racing applications. A decision to use a tube should be based on your application and needs. (Top)
