Drag Racing Tech
Flycut pistons/Cam only?
Old 07-05-2005, 10:33 PM
BAIN's Avatar
Default Flycut pistons/Cam only?
Well looks like the motor is a goner spun some bearings, took out the crank, and the pistons hit the valves because of a cut O ring in the oil pump So I'm going to get a new LS1 engine and put my T-Rex back in.
Question is....While I have the engine out and swapping in the new one should I flycut the pistons so I can run milled heads in the future? Would it still be considered "Cam Only" ????
Old 07-05-2005, 10:57 PM
SMOKIN01TA's Avatar
bain, we have a guy or 2 that have flycut pistons on that list
im just going off of the rule, stock rotating assembly and stock heads, all else is fair game cause these motors are wearing out and ppl might wanna do a refresh on them.
Old 07-05-2005, 11:39 PM
I can shift faster than you.
Jason99T/A's Avatar
