What size torx bit too take airbag off stock steering wheel?
Puttin on my new grant wheel today that my girl got me for xmas, and i'm just wondering what size torx bit to take the 2 bolts out of the stock steering wheel that hold the airbag in? Also, any other tips too help me through the install of the wheel? Right now i'm using the 3196 adapter kit, but eventually i'm gonna get the quick disconnect hub and pull it back off too put that on (my girl couldn't afford the quick disconnect so just got me the adapter and i've gotta start puttin money together for my safety stuff, so i'll just put the wheel in for now without the disconnect for a while).
You'll need a T-30. To get the new hub to engage the splines all the way you'll need to grind alittle bit of plastic on the inside of the clock spring housing. You'll see what I mean when you get it apart.
My wheel is deffinatly T-30, I just double checked. There are also only two holes in the back of my wheel with two bolts. Maybe '98-99 was different.
