Got the front travel limiters done
LS1TECH Sponsor
http://groups.msn.com/SteveDawn/ther...to&PhotoID=322
And, this should be enough room for true duals.
http://groups.msn.com/SteveDawn/ther...to&PhotoID=324
9-Second Club
Steve, I've got some limiters on mine that are adjustable from top, just open the hood. I have pictures, but the thing is, I can't figure out how to put the pictures in posts here. Can somebody tell me how? John said to "go into advanced", but I don't see any "advanced" here to select.
Thanks, Ed
Thanks, Ed
9-Second Club
[IMG]C:\top.jpg[/IMG] [IMG]bottom.jpg[/IMG]
The tubing is 5/8" and the rod through the center is 1/2", about 4" long. the 1/4" adjuster holes for the push-pull pins are 1/2" apart. There are four holes for adjustment, that is about all the room there is before the adjuster hits the bottom of the hood when pulled all the way up. These pics are from a friend's NHRA Super Stock '97 Camaro built by MPR (Mike Pestelney) Race Cars. Mine are just copies of this.
Hope this worked. <G>
LS1Tech Co-Founder
When you are replying to a thread, there are some buttons below this reply box. On says "Go Advanced" and if you press that, you can attach pictures to a thread. Let me know if it works.
It took me a while to learn how too. No one ever tells ya you have to save the pics somewhere else on the internet and then add the link. Go to photobucket.com and save your pictures there, its free. Then when you post here you just fill in the url for the picture you saved on photobucket.com and it will show the pic in your post. Hope that helps.
Ed, you should be able to get some info on this thread
https://ls1tech.com/forums/signature-testing-design/356036-signature-faq.html
its relating to signature posting, but the same principal applies with having img tags, and hosting.
PM me if you need some help.
9-Second Club
Originally Posted by LC1
noob here.. why are those needed?
So car don't bounce?
Seriously, it is to give you more control over wheel stands. If you limit the amount the front wheels can drop when the front end comes up, you kill some of the upward momentum, and lower the wheel stands. You can control it by slowing the front shock extension rates up to a point. Mine went past that point when the air improved this fall. I had to make up a set of limiters like in the pictures Jeff posted for me. A 1/2" adjustment makes a pretty big difference.
9-Second Club
If it doesn't have wheels or boobies, I don't know much about it. Heck, if it has boobies, I don't know anything about it. Some people will tell you if it has wheels, I still don't know much about it.
Sounds like I just don't know much.
