Clunks and Pops all over the place, what gives?
OK, run down on parts:
BMR K member and lower A Arms
BMR Subframe Connectors
Wolfe 6 point cage
BMR Extreme TQ Arm
BMR LCA ad Adj PHB
Wolfe Sway Bar
Hals all around
Whenever I drive the car in the street I am hearing clunks and pops everywhere. (Front, rear, middle)
While I expect some of this to be normal, how can you tell it it is exessive?
I have gone over every nut and bolt and everyting is tight.
I don't care about the noise much, I ma just wondering if it is safe.
Pops usually occr the most when going over bumps (Big and small).
Am I just paranoid?
Wolfe 6 point cage
BMR Extreme TQ Arm
BMR LCA ad Adj PHB
Wolfe Sway Bar
Hals all around
Am I just paranoid?
The rod ends will always make noise on the street. Keep them lubed up regularly and everything should be fine. It's also a good idea to inspect them every so often, as they will wear eventually.
- Justin
- Justin
