Slowing down on the big end
Ran the car last night for the 1st time since the 90/90 setup went on. I was spinning through the 60' most of the night, but I got a couple decent runs in. At the end of the night I ran 3 runs back to back with no cool down. The DA was around 2950' for all of the runs (Thanks Texas).
1st run:
1.93 (spun)
7.66@92.80
11.80@118.48
2nd run
1.83 (spun)
7.62@92.73
11.76@118.33
3rd run
1.58 (hooked)
7.27@94.62
11.42@118.42
So as you can see, I trapped almost 2mph higher in the 1/8th on my last run, but ended up at the same 1/4 mile trap as my other runs. And I actually hooked on my last run, so this confuses me even more. What would cause me to basically lose 1-2mph on the big end on this run? Nothing changed as far as weather or anything else between these runs. The car is shifting into 4th as I cross the traps w/ my 3.73s, 26" drag radials, and 4600 stall, but this happened on every run. Any ideas?
1st run:
1.93 (spun)
7.66@92.80
11.80@118.48
2nd run
1.83 (spun)
7.62@92.73
11.76@118.33
3rd run
1.58 (hooked)
7.27@94.62
11.42@118.42
You did not slow down. You should not expect the mph to increase on the big end when you got traction and ran what you should have in the 1/8th. In order for your mph in the 1/4 to increase you would have to increase your HP.
Your car should not be shifting into 4th gear with 3.73s/26" tall tires unless you either racing in OD or your shift points are too low. That right there could exsplain some loss in the 1/4 trap speed if it's shifting right before (50 feet or so) the 1/4.
