how much is 60ft going to drop with 300bl weight reduction?
how much is 60ft going to drop with 300bl weight reduction? my current 60ft is 1.53 weight is 3300 going to drop weight to 3050bl with brakes aliminum drive shaft ,kirkey seat, dry cell battery , no power steering,fiber glass hood,ewp,... the car is 347ci and th400 12 bolt moser
I ran 10.99@123.2 1.53 60ft last time .what is the effects of dropping 250bl-300bl on the et mph 60ft numbers?
thanx in advance
thanx in advance
.3 in the 1/4 all things being equal. 60' is more of a power and suspension thing if you ask me. Theoretically (TS6 did I spell that right ) 300 less bl's (hehe) should take less power to move so your 60 should drop but I would guess not by much. Also going to depend on where that weight is coming off of.
They say .2 drop in the 60' is worth .3 up top but I don't see that happening with your set up as it sits, or mine for that matter.
Originally Posted by Houston999
is that true?!
Good Luck,
Daren
Originally Posted by GIZMO
With a good tune you could probably drop your 10.9 to a 10.7 if you buy a good transmision and converter. Expect to pay as much as $3,500.00 for a good TH-350 set-up.
Good Luck,
Daren
Good Luck,
Daren
60' should improve nicely. With less weight, it should move better from a stop.
Al
Originally Posted by T6Rocket
Dropping 300 lbs should put him in the 10.7's without a tune or different transmission. Al
Daren
