Drag Racing Tech
Kill Switch wiring options
Old 12-09-2006, 07:20 AM
SlickVert's Avatar
Default Kill Switch wiring options
Is it possible to use a four pole switch and run the main starter wire to the switch then the battery as normal.
Then run the small field wire to the other poles on the switch to interrupt the field/output instead of the large feed wire?
Bob
Old 12-09-2006, 08:53 AM
6 & 8 Second Club
mrdragster1970's Avatar
They require all power is cut.
