BMR K member/madman manual rack
I have the BMR K member that uses the factory power steering rack and pinion, its this one.. PART# KM002 - Standard tubular k-member with LT1 motor mounts and factory power rack-n-pinion mounts. My question is that Im wanting to go to manual steering. Will either of madmans manual steering kits bolt up to this k member or am I going to have to change the whole k member?
LS1Tech Premium Sponsor
The Madman rack conversion works fine on our k-member
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Lee Spicher
(813)986-9302
LS1Tech Sponsor
http://www.madmanandcoracing.com/sho....aspx?itemid=3
Will fit k members that use the factory power steering rack. It comes with the correct bump steer kit, steering shaft, tie rod sleeves and new tierods. We have them in stock Give us a call 225-673-3533
and, yes, I could build one. I think anyone who wants to put in the time and effort could build one. It ain't rocket science.
Is this your first post?
I came up with 7 pounds difference between the two racks excluding the weight of the pump, pulley, hoses, bracket, and bolts.
