What else can I pull?
Originally Posted by Taubr Unit
holy hell im all about loosin any lbs i can. how the hell did you manage 2840!!
You need the driver weight reduction mod.
Serously though, yank out the heater and all that crap. Maybe convert to manual windows as well. I'd also put that horn back in while you're on the street. Never know when some broad won't check her blind spot and plow into you.
I'm seriously considering pulling the heater though. I've been trying to decide whether to do it or not.
Actually the 2840 lbs is the race weight with me in the car. I tip the scales at 200lbs so the SS alone weighs 2640lbs.
It took alot of work to get to this weight. The SS has been converted to manual windows, locks,and mirrors. Also trimmed/shaved, lightweight carpet and the list goes on. Use the search and you should be able to find some info on what we did to the car. Also there is allot of info in the forums posted by other on removing weight.
#33
Originally Posted by Project_SS
Wrong! The manuals are lighter.
#34
We drilled out the rivets that held the electric window assembly to the door. Pulled it out while one was holding the door glass up. Then installed the manual window assembly and put new rivets in. If I remember correctly the doors have the holes marked for manual or electric. Then pull out the wiring.
#35
#36
