how can i calculate corrected et?
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
just wonderingif there isa link available to calculate corrected et based on weather conditions.
tia!
taner
tia!
taner
Re: how can i calculate corrected et?
got to www.wunderground.com and get the weather conditions from the track (zip code is usually pretty close, then use the historical data and pick your date). then go to http://wahiduddin.net/calc/calc_da_rh.htm
and plug in the numbers, then go to somewhere like http://www.gnttype.org/techarea/misc/altitude.html
and use your calculator. Not the perfect way to do it but it will get you in the ballpark
Here is some more stuff.
First find the tracks altitude by finding it here:
http://www.racefan.com/racetracks.asp
Then go to here and plug in your times
http://www.prestage.com/carmath/calc...o_standard.asp
Then correct it for altitude like above.
My correct time went from a 13.314 to a 13.145 @ 108.48 vs 109.75
Bret
Bret
