Any other types of lightweight carpet out there?
What are you guys using? Right now I can't justify spending $200 on SpeedInc's carpet. Surely there's another option. Any suggestions?
Re: Any other types of lightweight carpet out there?
I know the speed ink carpet is a lot but it does fit very nice. Talk about expensive..... a guy i work with had to get new carpet for his sons 96 prelude.. only place you can get it is through the dealership....they only wanted $450
8 second mod
I just installed the Carpet from Speed, It fit OK, it looks good, not as good as stock but once I get a chance, Im going to try some spray glue. If you keep the Back seats it will look fine. I installed the Uncut, and it was in a 6 point roll cage car so it took a while. I will be installing a precut into a full int car in the next couple weeks.
I put everything on a scale as I did it.
Stock Carpet/insulation= 38#
Light weight=15#
Light weight cut and some insulation ripped off=13#
I guess 25# isnt to bad. And the Noise in the car wasnt all that bad.
Light weight=15#
LS1Tech Co-Founder
You can get rolls of thin carpet and it's like $7 dollars for a roll.
But go to any carpeting place and you will end up paying similar amounts to the Speed Inc. carpet since it's precut and molded.
