anyone use BMRs manual rack kit. pics please!!
i have a PA K-member setup for the factory rack so i know it wont fit. but i dont mind cutting off the old brackets and welding on new ones to make it work. anyone done this and do you have pics?
LS1Tech Sponsor
If your k-member is set up for a factory style rack then you will be better off getting my bolt in manual rack. If you are stuck with using the pinto style piece make sure you get all the geometry right with the mounts and then you will still need to build a bumpsteer kit and new steering shaft.
