windshield washer reservoir removal
This may be the wrong section but I'm looking for an easy way to remove that big wide windshield washer fluid container in the front of the car. Thanks
I just did this too. I just jacked up the car, disconnected the electrical plug for the washer fluid pump and then took out four (I think) small clips/pins that hold the botlle in. Then it just slids out the bottom...
Took maybe 5-10 mins to do.
Yep just comes right out the bottom if i remember correctly its fairly simple just 4 lil plastic pins unplug it on the bottom and she should pull right out the bottom hope this helps....
