Who makes an abs delete or who sells them
just wondering, does the SJM abs delete kit come with a line lock, or do you have to buy that also? I was thinking it didnt, but if not then what is the master switch and remote led for?
The kits are designed so that you can remove ALL braided lines in the engine bay. Braided lines expand under pressure to a greater degree vs. hard lines. The less tube expansion, the better the brake response.
The 139.99 kit is considered the base kit if you already own a LL and double flare tool. If you do not have a line lock or double flaring tool, the kits are available in a variety of configurations so that you do not need to purchase parts you already may own. For 40.00 more then the base 139.99 price, you'd receive the complete line lock kit with electrical needs including the master arm switch, control switch, remote LED, wire, electrical fittings...even down to the firewall grommet. If you need the double flaring tool, add 20.00.
All kits are in stock and ship within 24 business hours.
Hope this helps
