lower gear to overcome low stall speed....make any sense?
I searched for a topic on this but didn't find anything other than people arguing over 4.10's or 3.73's WITH a stall for the A4 cars. I was just wondering if it made ANY sense using a lower rear gear (I.E. 4.10 or lower) to overcome a low stall speed converter. It's just an idea....just getting opinions on this. If you took an A4 car and put a 4.10 or lower gear in it and didn't run a stall any higher than stock (or close to it) would you be able to launch the car anywhere near as hard as a higher stalled 3.73 geared car? If you had to drive the car in stop and go traffic every morning for long periods of time a stall might be a problem as far as heat....if the car had a street/strip set-up as far as rear suspension.....wouldn't using that low of a gear effectively do the same thing as far as putting the power to the ground when you launch the car? I know that the A4 car would probrably shift into OD before the traps.....if it was right before the traps it might not matter THAT much......what do you guys think.....If this is in the wrong section I'm sorry....I just figured the drag racing section was the proper place for this discussion....or tell me that I'm crazy discussion.....wich ever it is....thanks for ANY info in advance.....
The rear ratio should be selected without reference to stall speed. Your rear ratio should be such that your engine speed is above the power peak through the traps in top (non-overdrive) gear. At launch, a higher rear ratio will help a little but a higher stall will help a lot. It is best to optimize both. If you only want to change one, get a higher stall converter.
actually this sticky form the trans section answers lots of questions on converters..
https://ls1tech.com/forums/automatic-transmission/728728-commonly-asked-stall-transmission-related-questions.html
