loud drag suspension?
i just finished installing wolfe double adj. controll arms, a wolfe single sway bar, and comp. eng. rear shocks. ( and oztite carpet) I took the car out for a test drive and man is it noisey. every little bump or crack or pothole in the road and all i hear is " clack clack" sounds like my rear end was falling apart. i put the car up and checked everything out. it was all ok. so is everyone elses suspension this noisey? the actuall noise doesnt bother me, i just wantd to make sure thats how it was suppsed to be.
Noise here. But then again i think my Motor mounts need to be replaced. I'll post up after i do that and see if that is the only source of noise.
I beleive my LCA's and T/A clunk though. On uneven roads and loading and loading situations.
ssmoov1 on here has complete rod ended rear suspension with SJM lower control arms and panhard bar, not a sound of it. SJM told him a lot of times people use too small of bolts in the rod ends and that causes a lot of the clunking.. some food for thought.
