Drag Racing Tech
Need more cooling.....
Old 03-03-2008, 07:21 PM
1cdub's Avatar
Default Need more cooling.....
Where are you guys getting larger aluminum radiators for 4th gens? The added cubes of the LSX and the loose converter are taking its toll on the stock radiator. The longer I cruise on the highway it just continues to climb. Any tips on where to look? Thanks.
Old 03-03-2008, 07:43 PM
KCFormula's Avatar
I don't know how well it works but I know the LT1 rad is about 3/16" thicker than the LS1 rad. I actually have one I planned on using but haven't had a problem as of yet so its just sitting in the garage.
EDIT: after looking its more like a 1/2" bigger!! I can post some pics later tonight.
Old 03-03-2008, 07:52 PM
ROCNDAV's Avatar
B-cool several sponsors carry them, check with Futral or SpeedInc.
Old 03-03-2008, 11:17 PM
snake charmer's Avatar
b-cool is good . i have seen folks make small fins to add to the bottom of the black air dam . if you really want to get in it , remove the front bumper and on the bottom drill some holes in the bottome frame . you might be able to drill a few more holes in front of the black air dam .
Old 03-04-2008, 05:14 AM
Race your car!
JL ws-6's Avatar
Are you running a thermostat? If so, get rid of it.
Old 03-04-2008, 08:22 AM
LS1TECH Sponsor
Steve Burger's Avatar
We carry AFCO.
Old 03-04-2008, 02:37 PM
1cdub's Avatar
thanks for the info guys...
Old 04-20-2008, 11:06 AM
00BlackSS's Avatar
im using an lt1 rad with ls1 plastic ends! they are a decent size bigger
Old 04-20-2008, 08:03 PM
1cdub's Avatar
I ended up with the AFCO double pass from Burkhart....its the ****, plain and simple. Once on the highway I don't even use the fans at all. FAR, FAR, superior to what I was trying to use.
Old 04-26-2008, 06:17 AM
00BlackSS's Avatar
sweet glad to see you got it all worked out
