Where to put the ice?
On a different post i read that if you ice down your engine it's good for a tenth or two. But where exactly do you put the ice bags?
Re: Where to put the ice?
When I used it, I put mine on the throttle body and remainder on top of the air lid. The intake is impervious to heat. Cheers......
If it drips at the track they wont be to happy with you. I konw up here they get pretty pissed and stress not doing that over and over again.
In your cooler to keep your pop cold.
I have found that there is no difference in my ET as long as I don't let the car sit and idle.
I've made 4 passes in a row within 12-15 minutes with no slowing due to heat. As a matter of fact if there is a slow run it's always the first one. Plastic manifolds &TB coolant bypass rocks.
