Question about rims and tubes for slicks.....
If i have rims that have the valve stem hole already drilled bigger for running tubes, is it possible to ever run radials on it again?
i was told that once you run tubes that you are going to have to continue using them because you cant get a large enough valve stem to fit the hole needed for the tubes
is this correct or am i misinformed?
thanks
thanks
