Drag Racing Tech
Help with Torque Arm Decision
Old 08-22-2003, 06:38 PM
WMSuperSport's Avatar
Default Help with Torque Arm Decision
I'm trying to decide on which torque arm to put on my F-body. I have a choice of either the Spohn unit or the BMR trak pak. The car has M6/heads/cam/intake/4.10s/15x10 draglites/26x11.5x15 ET Streets/100 shot/Dennys 3.5"(?) HD Aluminum driveshaft. I haven't had a chance to get any good runs on the setup, but I'm concerned with durability and weight, along with cost. I plan on keeping my car near factory weight.
I plan on using a torque arm that mounts to a crossmember, instead of the tailshaft. Any information would help. Thanks,
Wes
Old 08-23-2003, 08:26 AM
GeorgeC's Avatar
Default Re: Help with Torque Arm Decision
Given those two choices, I like the BMR piece much better...
I'd still take my Madman torque arm above any others, though...
Old 08-23-2003, 12:54 PM
romanss's Avatar
BMR all the way. The extremem piece has served me well.
Old 08-23-2003, 12:58 PM
more carbon's Avatar
is the global west unit o.k.??
Old 08-23-2003, 01:19 PM
Formerly 4mulaJoe
LS1x2's Avatar
The BMR Trak Pak is good. Installation is quite a task though. You also loose some ground clearance. On my car I do not have clearance for a 3.5" with the Trak Pak.
Old 08-23-2003, 01:41 PM
George, I like the MADMAN unit as well, but it's a little overkill for my car, I believe.
Thanks for all the responses. Do any of you Trak Pak guys run a 3.5" shaft?
Let's hear some words on the Spohn unit, will it clear a 3.5" shaft?
Thanks
Old 08-23-2003, 02:51 PM
Formerly 4mulaJoe
LS1x2's Avatar
It's more a matter of how you install it to whether it will clear. You will prolly just have to shortne a couple of bolts and "massage" the tranny tunnel with a mallet.
