2004 GTO Cam Only Dyno Numbers
Old 11-10-2008, 04:51 PM
Peetyz's Avatar
Smile 2004 GTO Cam Only Dyno Numbers
I decided to put my 04 on the dynojet and I was quite happy the mods to my car are in my signature. a vid and pic of the sheet should be up soon. The results were 387.94rwhp@6,300 and 372.73rwtq@5,000 Next mods are ported LS6 or Street warrior and Pro Products 85mm Throttle Body ...with those added looking to try for 400 wheel
Then later add PRC stg 2.5 5.3 heads or another type of heads and UD pulley with around 11:1 compression and try for 440+ wheel What do you guys think ?
Old 11-10-2008, 05:01 PM
BlkBird2000's Avatar
Not bad. How are you only cutting a 2.0 60' with DRs? I did that on street tires.
Old 11-10-2008, 09:40 PM
Peetyz's Avatar
The stock clutch with 388 wheel that does not like the radials lol new clutch is going in and then i can really launch car hard if i get my 60 ft down ill be 12.5/12.4 I could only launch stock clutch around 3,500 and it seemed to slip a tad Time will be better with new clutch that i can launch yea i did 1.9 on all seasons when car was about stock
Old 11-10-2008, 11:14 PM
registered user
ScreaminRedZ's Avatar
Very nice numbers! I think you definitely have a good shot at hitting 400 rwhp with a couple more bolt-ons.
Old 11-11-2008, 08:08 AM
Shorty Director
VINCE's Avatar
Very good numbers for a cam only setup.
Old 11-11-2008, 06:04 PM
Peetyz's Avatar
Thanks guys I was pleased especially because the IRS cars like the GTO usually put down lower numbers than like the Trans Am and Camaro ( someone correct me if im wrong)
Old 11-11-2008, 06:43 PM
LS1 SPEED's Avatar
nice results for the mods
Old 11-12-2008, 02:13 AM
Dan Stewart's Avatar
You sure it is the clutch slipping and not the DR's slipping? Can you smell the clutch burning?
I guess what I'm getting at is some dr's actually need to be heated up quite a bit before they grab (nitto's for example).
Also, make sure you are completely out of the waterbox before you light them up or you'll just throw water up into the wheelwell and then it will drip down onto the tires while you are lining up.
Old 11-12-2008, 10:02 PM
Peetyz's Avatar
Yea i usually can smell clutch and the pedal wants to almost stick to the floor at the end of the run on 3rd to 4th shift then pedal comes back after cooling and normal driving its just fine only acts up on hard shifts
388 rwhp on stock clutch is prolly pushing it esp since car has over 63k on her my buddy had same prob and replaced clutch and problem went away
Old 07-30-2018, 01:37 PM
Luke Henry's Avatar
Just got my 04 6speed at the dynojet... 319hp 329tq slp headers and exhaust only mods
Old 07-30-2018, 01:50 PM
Received 3,037 Likes on 2,365 Posts
Nice! You know this is a 10 year old thread, right?
Quick Reply: 2004 GTO Cam Only Dyno Numbers
