H/C/I/ Stalled A4 #'s. Low?
Old 04-07-2009, 10:30 PM
transam98989898's Avatar
Default H/C/I/ Stalled A4 #'s. Low?
I just got my car tuned today by Ed Wright. He took his time and did a great job with it but it still seemed a little down on power. It made 398 HP unlocked but through a big stall. Mods in sig. I only ran one locked run, just to see the efficiency of the converter and it made 412 but that was on the same baseline tune of 388 HP, so I'd imagine the same 10 HP gain on the final tune for locked to get it to 422 HP. Air/Fuel was rock steady at around 13. We ran it about 10 times and ended up with a slightly richer tune with less timing than the best run but only lost about 2 hp to be safer.
I know A4s dyno numbers don't mean a whole lot, but I thought I'd get a little more out of it. The torque was pretty low. I can't really remember what it was to be honest because the graph doesn't show it, only HP and Air/Fuel.
The HP curve was ridiculously flat though. There aren't RPMs, just MPH to look at, but I don't want to go find a calculator to figure it out. From 80 mph to 126 (6800 RPM cut off) it goes from probably 390-398 at a very slow incline. Sorry, no scanner for pics.
Does this sound normal, or low? Heads are milled. Compression should be about 11.9:1. Cam is 227/235 .614/.621 112 lsa. Taking it to the track this Friday. I guess that'll be the true test.
Old 04-07-2009, 10:33 PM
jsteele90's Avatar
stalled autos are not dyno queens. my 224 cammed and unported ls6 heads combo made 383/372tq locked. track times are what will determine the power of your stalled auto
Old 04-07-2009, 11:44 PM
Detoxx03's Avatar
That abnormally low. I made 418rwhp cam only
Old 04-07-2009, 11:47 PM
STEEPSS's Avatar
my buddy's 01 Z with a TSP torquer V2, Yank PT4000, performabuilt lvl2, and 3.73's in a 10 bolt only put down 350 on TSP's Dyno. buuuuuuuuuuuuuuut, that's a mid 11 second car.......
dynos are for tuning and bragging. show me some track times.
Old 04-08-2009, 03:53 AM
john563's Avatar
I have that same stall with tsp 5.3 heads a 232/238 cam and put down 426rwhp..when I had a 3500stall and 3:23 gears I put down 435rwhp..Added 373 and put down 424rwhp then swapped out the stall for a 5c,and my hedmans for hookers and put down 426rwhp..The car feels tons faster though
Old 04-08-2009, 06:59 AM
LS1 Tech Administrator
Patrick G's Avatar
Stalled autos will normally be 40 rwhp or more down compared to a 6 speed when they're unlocked. Funny thing is, they usually ET better than the 6 speeds. Your numbers actually sound good. Ed is a very skilled tuner. You will probably ET well into the 11s with that kind of power.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 04-08-2009, 07:26 AM
allngn_c5's Avatar
^^^^^^^^^^ Well you heard it from the man ^^^^^^^^^^^^^^^
Old 04-08-2009, 07:58 AM
LS1Tech Sponsor
Slowhawk's Avatar
Thats a 10 second car.
Old 04-08-2009, 08:06 AM
Detroitmuscle's Avatar
Your numbers are abnormally high actually my car didn't break 400rwhp with a MS3 and ETP 5.3 heads but it ran mid 11s full weight. Take it to the track and then decide weather or not you care about those numbers
Old 04-08-2009, 08:16 AM
crzytown69's Avatar
i agree mine is only 427hp and like 370ish tq and its a whole nother beast on the road
Old 04-08-2009, 08:38 AM
firefighter813x's Avatar
Assuming you hook, I would agree. Definitely a solid car for 11's. I'd be happy! Please do post results from track asap. Is it a 1/4, or 1/8 track?
Old 04-08-2009, 08:45 AM
PewterScreaminMach's Avatar
Number look normal to me considering the drivetrain and the heads/cam you went with. That car will be low 11s all day long if you can hook, possibly high 10s at a decent track/decent weather.
Old 04-08-2009, 09:36 AM
It'll be at a 1/4 mile track (MOKAN, it's not very well prepped) and I probably won't hook well. I'm still running Nittos on 17's. My car is a pig and I'm about 225 lbs so my motor will have it's work cut out for her. The best I did before was a 1.71, but most of the time it is closer to the 1.9 range. I've only had about 4 passes on this converter and am trying to find a good launch RPM. I'm a little bit relieved that most of you think that they are fairly normal numbers. I'll post up track times after Friday if weather allows some passes. Regardless of 60 ft, I want to see an improvement on my old 113 mph, because that'll tell me what I could be capable of if I had some drag wheels and M/Ts.
Old 04-08-2009, 10:32 AM
jpajkos's Avatar
Here's my mods
Patriot Stage 2 heads milled to 64cc
Cam specs: .234-.238 .646-.613 on a 111lsa
Un-ported F.A.S.T. 90 Manifold
Nick Williams 90mm TB
Hooker Longtubes
Hooker ORY
Ported Descreened SLP 85mm MAF
SLP Lid w/ smooth bellows
Free mods
SMi built 4k stall w/ cooler
3.23s
Im probably forgetting some other stuff but I made 440 rwhp @ 417 rwtq locked. I was thinking about milling my heads some more to bump my compression. Im going to chop my exhaust off and weld some turn downs off the longtubes. I was thinking about porting my manifold to see if I could hit the 450-460. I know it's a long shot from hell but worth a try. Im sure you'll do excellent at the track.
Old 04-08-2009, 12:05 PM
gruntwork's Avatar
3.73's eat about 10hp or so. 409hp 386tq, 11.7@116 with mods in sig.
Old 04-08-2009, 12:37 PM
johnster's Avatar
i did 455/407 mods in sig locked
Old 04-08-2009, 04:07 PM
Detoxx03's Avatar
Oh I have
Old 04-08-2009, 04:42 PM
crzytown69's Avatar
Oh I have
lol
Old 04-08-2009, 06:41 PM
9 Second Club/Nitrous Mod
shortdog's Avatar
Your numbers are fine. You should run mid to high 11s @ 115-118 mph, but if you end up running 12.4s @ 111, then worry. Dyno numbers does give an indication, but don't get caught up on it. Save the bench/dyno racing for those that brag on dyno numbers and never sees a 1/4 track.
Old 04-08-2009, 07:08 PM
JaSSon's Avatar
Dont be bothered by those numbers, I dynoed 333rwhp cam only with an A4 ran 11's all day long in any weather. The dyno is a tuning tool. My car now is around 450rwhp with a 230 am and cheap heads and I roast Cobras and LSX strokers at the track weekly. Put a sticky tire on it and go to the track!
Quick Reply: H/C/I/ Stalled A4 #'s. Low?
