LS1 cam only + 150 N20 A4
I'm trying to post this using winPEP7 that Dyno Jet uses.
All runs were unlocked. Some reason the torque will not show up. Maybe I can forward the graphs for someone else to post???
If it doesn't show...
N20 @ 150 (gained 120 roughly)
478hp 457tq STD unlocked
467hp 446tq SAE unlocked
N/A (graph won't show torque
386hp 35X tq locked STD N20 tune
358 3XX STD unlocked
Stats
'98 B4C 128k
Pacesetter 1 3/4 LT+ORY with Borla XR-1
230/228 112
Melling pump
stock 806 heads
Autolite 103's
Precision Industries Vigilante 3200 single disk/RPM level 5 4L65e
10 bolt w/3.23
Lightly ported Fast 90/90
MSD wires
GM 85mm MAF
MTI transparent lid
NX single nozzle wet kit with 150 jets
Racetronix pump
37lbs injectors
Anything else just ask.
Chris
Stats
'98 B4C 128k
230/228 112
Melling pump
stock 806 heads
Autolite 103's
10 bolt w/3.23
MSD wires
GM 85mm MAF
MTI transparent lid
Racetronix pump
37lbs injectors
Chris
Jedi Master
You can modify the parameters that are displayed on the chart. If I had Winpep still installed I'd give you more specific instructions. You can change the x and y axis paremeters, add torque as an x parameter
I've never taken it to the track! I want to really bad but do not have drag radials. I'm thinking about making it a dedicated weekend warrior/track car soon. Might save for a race wheel setup soon.
2002camaroSS- How did your MTI car run with the X1 setup? Numbers?
Great #'s. And thanks for the reference of locked vs unlocked. I have same converter with H/C and put down 392 unlocked. I've always assumed ~20 diff locked and with your 28 looks like I'm in the park.
