603 rwhp 583 rwtq - LS3 427 NA!!
LS3 427ci built by Hinson Motorsports
Naturally Aspirated, Pump Gas, Hydraulic Roller
- LS3 427ci Shortblock
- Trickflow 235cc CNC Ported Cylinder Heads
- GM MLS LS7 Head Gaskets
- Yella Terra Ultralite Roller Rocker Arms 1.7 Ratio
- Hinson Motorsports HM1 Camshaft
- Ported FAST 92mm Intake
- FAST 92mm Throttle Body
- SLP 25% UD Pulley
- Stock GM Water Pump
- Hinson Motorsports 4" Cold Air Intake
- Hinson Motorsports 1 7/8" Long Tube Headers
- Hinson Motorsports 3" Y-Pipe
- Hinson Motorsports 3.5" Exhaust System
- SPEC Stage 3+ Clutch
- SPEC Steel Flywheel
603 rwhp 583 rwtq
- SLP 25% UD Pulley
603 rwhp 583 rwtq
Thanks guys.
These are our RX7 conversion parts. It's in a 94 RX7.
It's using a Magnaflow Muffler. The Camshaft is 24x duration with big lift.
We are not a sponsor on this board so I can't post that information.
Compression is 11.3.
Factory Mazda IRS with 4.10 Gears.
