370ci Rearmount turbo 76mm ball bearing
This is a 2002 SS Camaro
Here are the results of my turbo build: 808rwhp, 880 tq on a mustang Dyno
My build:
370cu iron block
diamond pistons
stock crank
ARP everything
turbo cam spec by Tony Mamo
AFR 225 heads 73cc
Comp star rods
80lb injectors
76mm precision turbo with 1.32 twin screw housing
12 bolt rear
M6 with Mcleod twin disk clutch
18.9 lbs of boost
meth kit w/ twin nozzle
Bump for the rearmount turbo guys
My build:
370cu iron block
diamond pistons
stock crank
ARP everything
AFR 225 heads 73cc
Comp star rods
80lb injectors
12 bolt rear
18.9 lbs of boost
