STS Rear Mount Dyno with 67mm and 76mm comparison
Finally dyno'd my camaro. This graph shows the difference between the stock GT-67mm ballbearing turbo compared to a Turbonetics 7575 turbo on my 402ci low compression motor running at the same amount of boost (10 #)
This dyno run is #4 where after we were correcting the AFR's we noticed a loss in power, so the initial tune was reinstalled to bring the numbers back up to where they sit.
Cam Motion Turbo Cam 228/222 (Duration 576/576) Lobe Separation 0.115
Should be good for 6500rpm redline and peaking around 5800rpm.
Not quite the build i was hoping for.
I have come across some information suggesting that the 2.25" boost tube from turbo to intake manifold may be a restriction causing the drop in power....and i've also come across information that suggests by adding more boost the horsepower curve should trend a bit higher.
So next season, i'll upgrade the fuel system...yet again and see where the fault rests.
