how much power will she make and et guesses?
Old 03-24-2015, 09:18 PM
penningta's Avatar
Default how much power will she make and et guesses?
Here is my build. I'm curious to see what you guys think it will make power wise and what the car will run.
Motor is a 6.0 .030 over.
Stock crank
Callies h beam 6.125 rods
Je asymmetrical 11.1 cc dome pistons
Prc ls3 cnc heads with ti retainers and dual 650 lift springs. They are supposed to flow 340 ish at 600 lift I believe
Super vic intake
Cammotion hydraulic roller 245/252 621 612 111 lobe sep 108 int c/l
Morel ls high rpm race hydraulic roller lifters
Brian tooley ls3 trunion upgraded cyro coated and polished rockers
750 carb on 112
Car is a 2800 lb fox body with a glide and 28 10.50 15 slicks
probably around a 5000 stall. Havnt had it built yet. Car went fastest at 10.13 on old sbc 355 setup. It made 525 hp on dyno. This is flywheel hp
Old 03-24-2015, 09:42 PM
one fast zo6's Avatar
525whp 9.80et
Old 03-26-2015, 10:26 AM
LS1Tech Sponsor
CAMMOTION PERF's Avatar
Looks like a solid 9 second combo. When will this be on the track?
Old 03-27-2015, 03:42 PM
penningta's Avatar
As soon as you ship out my cam!! HAHAH just kidding. Just got a call 2 days ago that you are out of cam cores. I hope to get the motor pretty much assembled next weekend so I can messure for push rod length. Then its off to the dyno so I can get my converter built. Hope to be at the track in 2 months!!!!!
Compression is going to be right around 13.1-13.2 compression. SHould make for a solid combo
Old 03-27-2015, 04:14 PM
LS1Tech Sponsor
Yes sir. We were waiting on the newest batch of 8620 cores to come back from heat treating. A batch came in on Thursday and we are prepping them to be ground now. Give Danny a call on Monday and we will see if we can get yours going ASAP.
Old 03-27-2015, 04:20 PM
penningta's Avatar
Will do. Thanks again. From the pics Ive seen of these 8620 cores they almost look to nice to put in a motor!!
Old 03-30-2015, 11:32 AM
penningta's Avatar
HE said I should have it Friday!!!!!
Old 04-01-2015, 10:17 PM
penningta's Avatar
What oil would you guys recommend for break in of this combo. Lifters say nothing heavier then 5w40. I was going to run 5w40 Schaffer synthetic oil. But have heard many times not to break a engine in on synthetic
Old 04-01-2015, 10:30 PM
Zmg00camaross's Avatar
Regular ole carquest 5w30
Old 07-18-2015, 09:56 PM
penningta's Avatar
DYNO results
Old 07-19-2015, 10:12 AM
Jimbo1367's Avatar
LS1Tech 10 Year
Good Numbers. 600+ dam
Old 07-19-2015, 11:16 AM
Old School Heavy
speedtigger's Avatar
Look how the power just carries. It just goes and goes.
Old 07-19-2015, 07:18 PM
penningta's Avatar
Yeah and his dyno is a true dyno. What it says is pretty close to what it is. If you take hp to weight calculators. It's almost spot on to what my old setup made when I had it done there
Old 07-22-2015, 05:06 PM
LS1Tech Sponsor
Good work. I bet it is going to rip up the pavement.
Old 07-23-2015, 05:33 AM
Mr Monaro's Avatar
Wink
I was going to add top notch service with commotion Kip and crew very happy.
cheers
joe
Old 07-26-2015, 02:27 AM
SSZ
SSZ's Avatar
Nice work by Cammotion for coming through on the cam. Its good to see sponsors coming through like that.
Interested to see WHP and track results. Good luck and nice numbers. Like Speedtiger said, talk about the power hanging in there!!!
Old 08-20-2015, 03:08 PM
penningta's Avatar
Well I finally made it to the track!!!! Converter is a little to tight. Its flashing about 700 rpm lower then I would like it to> Hopefully thats whys its slower then I thought it would be. But still felt good to be back in the seat. Got a little rust to get figured out on the tree again. .005 light but on the wrong side in this pass. Damit.
Car went 10.11 in my only 1/4 mile pass with trans brake at 3500rpm. 1.426 40ft with 6.429 @106.99 Next pass was trans brake at 4700rpm went 1.414 60ft 6.395 @107.56 1/8. Clicked it off. Started raining at 1/8 mile. Only one more pair went down after me.
Here is a link to vid of last pass
https://video-dfw1-1.xx.fbcdn.net/hv...43&oe=55D6501D
Old 08-27-2015, 11:44 AM
penningta's Avatar
the links only work for a few hours and stop. I give up
Quick Reply: how much power will she make and et guesses?
