Finally dyno tuned my car... Highest hp "bolt on" ls1?
#41
I did it just to see what I could get out of the car. I want to hit 10's with the stock heads and cam.
After that, I'll likely do cam and heads on it.
#42
I have three questions.
1. Why, is it just for the challenge? Looking at everything you would have to optimise engine and accessory wise plus I assume a lightweight flywheel, clutch, drive shaft (manual) or auto mods, rear end and wheels etc, etc just to say it's "bolt on", surely it would be less expensive to buy even the best set of heads available and an aftermarket cam to make the same or probably more power.
2. Devil's advocate here, technically a stock LS1 cam, slight regrind maybe?
3. Have Big Hammer and HioSSilver ever been seen in the same room/area at the same time?
Jason.
Jason.
2. All ls1 cams were ground...even the stock ones
3. No we haven't. ....but we were planning on touching wewe's at mir. Until then sexting will have to do.
#43
1. Why not? Hp is hp....tq is tq. Both help a car accelerate. Optimization of the stock heads and cam will surely lead to a better h/c car
2. Thanks for the tip but regrinding the stock cam with some slightly improved specs was what I was alluding to.
3. , probably a little too much info.
#44
Moderator
Received 1,836 Likes
I think hammer has been very open about how he did it. Here's the build thread...
https://ls1tech.com/forums/generatio...b-spacers.html
TB spacer FTW!!! Still the funniest thing I've ever read on here!
#48
Giving out my cam specs doesn't help anyone. But I can say that I've help hundreds of racers in some capacity and would rather teach how to fish then to hand someone an old fish that was once the king of the pond.
The funny thing is that ones who benefit from the info and run some successful and even record times often catch a case of amnesia and conveniently forgot who got them there. But the ones that do appreciate the knowledge and the effort make it worth while.
FWIW, my ls6 bolt on setup made 413 on a mustang dyno that reads more than 10% lower than the local dynojet, thru 4.10's and without any effort to make a high dyno number.
Give'em hell at the drag strip Hammer!
#49
Thanks for the insight. It's just that shape that makes me think.
I also mean no disrespect to hammer. His car is strong.
I did a quick sketch (didn't even use a ruler) of his curve. Here is also a baseline pull to 1 3/4 long tube, ORY, magnaflow on my car. I know it's really not apples to apples. Just to show curve of my stock 01 cam to hammers.
I know changing things can change the shape of the curve. Say an ls style manifold swapped for a straight runner manifold will def change it up a bit. As the cam is the heart of the motor, the valve events are very important to the curve. As you know.
If it is what he says, great job!
#50
I share a ton of info all the time. I just don't always spoon feed it to people who are looking for some quick fix that doesn't exist. A lot of times if you read up on my threads you'll find most all the answers you want but it's not my passion to make build threads. In fact I dislike even reading them. People have been pm'in me for the past 10 years and I do my best to help them with their setups.
Hio helped me a lot get started and for the last year or so we have bounced ideas off each other daily. I'm actually pretty excited to see how his car does next time out now.
I will say that the entire LS1 intake system is restrictive and to avoid small headers and Y pipes. Other than that this is the only time I've dynod this car so I'm still guessing somewhat on how much each particular mod added.
There are a lot of places on these cars reducing the SAE net ratings. More so than newer cars IMO
#52
I honestly did not mean to come across like I have my panties in a bunch. I just really hate the secret squirrel BS associated with modding cars. Everyone hides cam specs like it's a freaking treasure map.
I think you should share everything, challenge someone to build an exact replica of your badass racecar, and then beat them because you are the better driver. Ultimately, I always thought that modding cars was about building better and faster machines to challenge the driver to become better and faster.
Hunter S. Thompson (RIP) once said that men like big guns and fast cars because they push us to the limits of our abilities, instead of us pushing the machine to its limits.
What harm is there in transparency unless you aren't a good racer, and just have a fancy racecar?
That being said, those are strong numbers for a stock cam and stock heads. Good job. I am all for optimization and maximizing efficiency, and your attention to detail has definitely done both for the stock heads/cam.
#53
Stock heads/cam LS1's will not make that kind of power NA. Regardless the car does run great and makes great power. What I find odd is you make more power then Hio's FBO LS6 but trap what 10 mph less then Hio? I have seen enough setups over the years to know something smells fishy here...and there is only so many bolt-ons you can do. Yes I know all the little secrets, not my first rodeo. Either way congrats and keep them Furd boys on their toes.
#55
Are you saying the OP doesn't have a stock LS1 cam and 241 untouched heads?
#56
Never PM'd OP but I have with Hio quite some time ago and was given some information in regards to clutches, trans mods, and weight savings and things of that sort but not a ton which I could apply but I still stored it in memory.
There are plenty people on the site who have legitimate interest in learning and realize it's a matter of optimization not just simply buying and installing parts, but finding where to begin and where to dig deeper can be a challenge. At some point it just is cumbersome to keep asking questions and feel like a pest. Hence my previous post in this thread...became fairly clear OP didn't have much interest in discussing details so pressing the issue just seemed like a waste of time for both parties.
I often receive PM's about various things and try to help best I can. But I also take those questions and apply them to the threads which spawned them so I don't have to keep answering the same questions in detail and can just point to the thread.
That said, not everyone has the desire to do so for whatever reason they might have. Nothing to lose sleep over.
Good numbers none the less.
#58
Apparently they do. What makes you think they can't?
#59
Aside from that Hammer likes to troll, so unless his comes clean and lists his mods I am not buying it. His car runs great no doubt, not knocking anything. Dyno numbers are meaning less for comparing across the nets anyway.
My car trapped 115 with 330whp and went low 12's with stock stall and 3.73, 1.85 rockers/springs, ported TB and **** hooker header and cb exhaust. Added full looks setup with fti 3800 and picked up 2 mph. a fast 92 would of put me right at 118-120mph. So I know bolt-on LS1 cars can run, just saying the numbers seem high.
#60
No they don't... your hellion cam car made less power. As Redtan said in 19yrs nobody has documented a stock internal Fbody going over 400whp. Closest I seen was a stock cam AI 241 headed car put down 417whp with a ewp and short belt.
