LS6 Intake swap before and after dyno #'s.
My baseline dyno was a 99 MN6 LS1 with only engine Mod being a Blackwing. I just dyno'd the car after the change of intake being the only engine change. I do need to mention that the last dyno was on the BFG DR's mounted. Since I have changed to the F1GSD3's for the winter season. How much can this effect the outcome? Not much I believe.
I started at an average of 315.3HP and 323.1TQ. My average of 5 pulls after the LS6 intake swap is 322.9HP and 329.3TQ. This is a net positive gain of 7.6HP and 6.2TQ. Not bad but I was hopeful for more. I did not do the coolant bypass on the Throttlebody. Long tube headers would likely really compliment the new intake.
One special note. During back to back pulls I removed the tube that connects the TB to the passenger side valve cover (PCV). The resultant tube on the TB was capped. This net another positve gain of .6HP. I have re-connected the tube and will be thinking of adding a filter on the tube to permenantly remove the hot vapor from the TB.
Here's my report so what do you think?
LS1 Tech Administrator
Nice gains. Add headers and some cam duration and you'll see another 10 rwhp from the intake alone...easy.
Not too many people report seeing gains on a bone stock motor. Glad you did. This confirms why '01-02 F-bodies make a little more power than ''98-00 models, even though they have smaller cams. The intake does help. A 2000 model with the bigger cam like the '98-99s and the better manifolds like the '01-02s would make the most power of all years, but it's nothing compared to what any model can make with long tubes and a bigger cam, LOL.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by TheBowtieboy
You might look into a better exhaust/muffler.
.....cheap way to free up some HP
Originally Posted by ROJO99
I have hought about a Cat Back, but decided to channel the funds towards LT's.
Add a loudmouth and lid it might be the proverbial factory freak.
Originally Posted by dug
Dont forget about a 2000 car with the 241 heads. It would be interesting to see how strong a car with a 2001 intake, 241 heads, and the 98-00 cam and 2000-02 exhaust manifolds would be.
Nothing much. They just flow a lil better than the older castings. I read the old heads are sand castings where the newer ones are mold castings. The mold castings is supposed to be smoother.
I have a 2000 WS6 built in Feb. 2000 and it has 853 heads.
__________________
I don't think you can pin it down accurately unless you have your car tuned on the same dyno 9same weather conditions) before and after the swap. Once you do the swap, you'll need to tune it again to determine an accurate gain. I say this because the additional airflow should throw off the A/F by .2 - .3. That's only one factor.
I've seen dyno sheets that show the LS6 swap has yielded nearly 30 RWHP gains. Typically, I believe 12-15 RWHP is about right. With a cam of very large duration, and full bolt-ons, I think you could see 25RWHP.
