More TSP/PRC ls6 heads and MS3 #'s
Bad Seller Alert
mods are: stage 1 prc ls6 heads with stock valves
MS3 cam
bbk 80mm tb
pacesetter lt's
3 inch ory pipe
hooker catback
lid
ls6 intake
Dyno #'s
422HP
368TQ
This is through a 9 inch rear with 4.11 gears
The TQ is lower than expected but Mikey at Rapid said the hooker catback is hurting the #'s
A few more bolt ons and it should make a little more power
A big thanks to Mikey at Rapid Motorsports. He has tuned my car 3 times and i would highly reccomend his skills to anyone.
I will see if Mikey can post a gragh later today.
MS3 cam
bbk 80mm tb
pacesetter lt's
3 inch ory pipe
hooker catback
lid
ls6 intake
Dyno #'s
422HP
368TQ
LS1Tech Premium Sponsor
Definately think she should make a little more power, try putting a cutout on it! The last one we did made well past that. I would expect to see about 390-400 torque.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Its common for the hooker aerochamber baffle inside the muffler to break loose and restrict flow. It happened to mine. Does the muffler ever rattle? Id definitely try a cutout. The hooker flows well until the baffle breaks loose after that it flows like ***..... That could defnitely explain the low torque output. Id say you have quite a bit left in the combo, once you find out the problem.....
Moderator
In reading through his other posts it seems that the old setup numbers were through a stock 10-bolt rear and the new MS3 cam and PRC heads were through the 9 inch rear.
Is this correct getlifted?
John
John
dont blame hooker, thats not hurting you, is a mix of the cam and heads, i see this over and over, torque is just too low IMO. my friend did better than that with stock ls1 heads and ls6 cam and a cat back i assure you was hurting more than yours. sell the heads and cam and get a proven combo, JMO
Bad Seller Alert
I agree the tq is way low. The difference in combo's is the heads were stage 2 with bigger valves, underdrive pulley, wide open exhaust, stock 3.42 rear on the old setup. I really don't know what to think at this point???? I have some rear end issues to work out right now.
Bad Seller Alert
John
John
Yes you are correct. But the tq is still way low
The hooker catback flows good in my opinion...
But ya might gain 10hp up top with a cutout.
You have a 440hp setup...but with the rear end your loosing power.
here is my dyno graph....high dyno was with the cutout open, the other is with it closed...
i lost 10.35hp/3.72tq
