Descreening maf gains?
Well based on the tune, I seriously doubt it would be a measurable amount. Now if your tune is way off one way or the other, it may make a slightly noticeable difference one way or the other. Recommendation: keep your screen on.
If you look at the screen closely you will notice it is honeycombed.Its other purpose,other than the bugcatcher theory,is to make the airflow laminate as it crosses the sensor.I figured out the value of the screen when I removed mine after installing the supercharger.The result was a small power surge in the engine at low rpm.I reinstalled the screen and it disappeared.There was nill difference in power with or without the screen.
LS1Tech Editor
Checkout installuniversity.com, I believe they did a test on it and said that the small gains come from the ignition advance as a result of the disturbed air, not from increased airflow.
My two cents.
My two cents.
LS1Tech Editor
http://www.installuniversity.com/ins...sity/index.htm
Click the tech articles on the left side and then click the "Maf flow 101" about mid way down the page.
Originally Posted by MeentSS02
There is something to be gained from it...flow bench testing can prove that. It is most definitely not designed to be a bug/leaf catcher though...if you are having those items appear on the screen, you need to seal your airbox.
But, it is not a bug catcher! If you have crap on the MAF you have problems.
