Free Desktop Dyno Results
i just got this desktop dyno i want to get my money's worth out of it and help you guys at the same time all i need is this info:
BORE_____
STROKE______
COMPRESSION RATIO________
HEAD INTAKE RUNNER CC'S______
HEAD EXH RUNNER CC'S_______
HEAD PORTING, CLEANED UP, MILD,PERFORMANCE, FULL RACE________
INTAKE VALVE SIZE_______
EXHAUST VALVE SIZE________
CAM DURATION @50 INTAKE_________
CAM DURATION @50 EXHAUST________
LIFT INTAKE VALVE__________
LIFT EXHAUST VALVE_______
LIFTER, CAM AND ROCKER STYLE ROLLER, SOLID, HYD, ECT...________
FUEL INJECTION IF YES I NEED INJECTOR SIZE_______
CARBURATED IF YES I NEED CARB SIZE_______
WHAT STYLE INTAKE DUAL PLANE, SINGLE PLANE ECT..._________
WHAT TYPE OF EXHAUST________
ANY OTHER POWER ADDERS, OR OTHER INFO WILL HELP WITH ACCURACY.
RESULTS INCLUDE:
STP HP AND TORQUE
SAE HP AND TORQUE
REAR WHEEL HP AND TORQUE
1/8 ET-MPH
1/4 ET-MPH (THESE ARE BOTH MEASURED WITH A 3200LB CAR AND 160 LB DRIVER)
NOTE: THESE ARE NOT MY FIGURES SO IF THEY ARE WRONG DON'T COME CRYING TO ME PLEASE.
PM YOUR REQUESTS PLEASE.
BORE_____
STROKE______
RESULTS INCLUDE:
STP HP AND TORQUE
SAE HP AND TORQUE
1/8 ET-MPH
I have that program too. I think mine came out around 2000. I've experimented around with different combos, and it's always within 5% of all the numbers of various magazine articles on engine dyno results in both torque and hp, including AFR's recent dyno results now posted on their site. My version though doesn't take into account head port sizes, or recognize a steep ramp rate cam from a regular grind or anything like that. Did they come out with a new version?
Jason
Jason
I just ran a 402 with TEA's LS6 Stage 2.5 heads, T-Rex cam (using 107 for intake centerline and 110LSA), and 11.2:1 compression and got 570 peak hp @6000rpm and 564ft lbs @4500rpm. This was using "small tube headers with open exhaust" to simulate true duals and 900cfm on the intake to simulate a FAST setup.
Run this setup on your program and see what you get. Also if you could, post a link to where you can order your version. thanks
Jason
Jason
here is the link http://www.virtualengine2000.com/ but i would need more specific info from you to run your setup.
I noticed yours doesn't seem to have provisions for cylinder head flow data. Does it just ask for port and valve sizes or can you manually enter in specific flow numbers? My DeskTop Dyno does this but not the size of the ports.
Basically, I'm curious and may end up upgrading software programs if I can find one that utilizes the following criteria in addition to what mine doesn't do:
flow numbers and port size and shapes along with the angle of heads (23 degree, 15 degree, etc)
injector size
rod length
cam ramp rates by entering in seat to seat specs and .050" specs
Jason
injector size
rod length
Jason
